Hi,
I made a comlex image (with BlindRead) consisting of several well defined files (I mean - .bw, .bws, .bwa & .bwi). According to BlindWrite (and every other image burning soft I have access to) it is a perfectly well made image. All the data (physicall information, weak sectors, sys inf, etc) is correct. There are no problems with burning it, either.
Problems strat when it comes to mounting it. Both DT4 and Alcohol120% report that "file is unaccessable". WTF should it mean?
I spent seveal days over the case, and managed to eliminate most of the stupid reasons (for example - access right, and so on).
Ever encountered such a sympthom?
To give some background - I'm a "proud" user of WinXP HE 2SP.
I wonder if I chose a correct board for the topic - it is a kind of "cross-board" to me... If not - sorry.
