I know everyone has been posting about Empire at war, so I am... i crumble under peer pressure.  Anyways... I'm having all the same problems, but i've never had the security error, its always been either it found an emulator, and when i fixed it couldn't find a disk.  I have tried everything, and got it to work twice, but never the same way.  One time when I finished, and went to play again, it didn't work, so I fiddled until it would again, but the same thing happened.  I saw where someone said that it might be accessing the internet to check for this programs, but I doubt it.  Does anyone have a 100% sure fire way, thats worked more then once?
Sneaky Sneaky Lucas Arts
step by step introduction how to play star wars - empire at war
if you follow this steps you will be able to play without any problems.
1. raise your hand and reach out for your purchased copy of eaw
2. open the box
3. take out the dvd
4. with the other hand push the open button on your dvd drive
5. put the dvd in the drive
6. close the drive
7. wait for autoplay to start the game
8. press start game and enjoy
with best regards burnsy_xyz
Lusitania
A very simple method that will run your game without scratching your original disc is this method, and it works every time.
Make a back-up on on a real disc.
Put the disc in a real optical drive.
When the splash screen appears quit out of it, or hold shift key.
Start securom-loader and point to excutable in game data folder NOT the splash screen excutable, it will load into game everytime with this method...also patch the game first.
