Windows 2000
  • Windows 2000
    I have backed up my legit copy of windows 2000 to a iso but is it possible to use this software or any other software to install it?
    u can't install ur OS from an mounted image. How could u mount the image without an OS to run daemontools?
    A mouse is a device used to point at the xterm you want to type in.
      i have installed winxp sucessfully using a mounted image.it can be done if its an upgrade!
        Of course you cannot install an OS without having burned it on a cd because daemon tools itself needs Windows
        But never heard about upgrading to XP using daemon, wow, fantastic, congrat
        But it's better to have the OS burned on a cd anyway
