Ok, after several hours of combing through these forums, and trying different things, I finally got my fix, and verified it on all 4 of my home systems, I figured I should post to help others. Ok, so I installed it, and I burnt an image using an older version of Alcohol 120 (1.4.8) using DPM at 4X. Then I installed the latest version of Daemon Tools, and mounted my image, leaving all options disabled, and then closed daemon out. Then I installed CureRom and used the downloaded profile. I went through it, and went to options, and set it up so it knew the link to Daemon, BUT, when I closed that out, then hit next, I left the option where you say "No I dont want to use a third party virtual rom device" After that, I let it create its shortcuts, and it works fine. After I updated my kids computers, I did have to re-go through the steps, but works fine now. Been running it for a couple days now. I am glad because I hate using the original disk to start up. Anyway there is my fix.
Now if someone will come out with a fix for Star Wars Battlefront II version 1.1, I will be good to go.
SJRACER
SJRACER
