anyone know how to burn the alcohol image of this expansion pack for sims 2. i think im using the wrong options. after i burn the game and try to play i get a message saying that there was a problem and that the program must shut down.
sims 2 open for business
Turn SafeDisk emulation off in Daemon Tools.
What copy protection does Open for Business use?
Does it work from the original CDs? Does it work from images? A lot of the more recent copy protections cannot be burned to CD-R anymore, but they will still work if proper(!) images are mounted with Daemon Tools. How did you create the images you're trying to burn to CD-R?"I was inappropriately blunt, wasn't I? Sorry, I do that a lot."
so you need thisOriginally Posted by BlazkowiczIt uses Safedisc 4.6.
How GameBurnWorld went from a 2002 archive of PC game fixes and trainers, through a chapter covering online casinos and payment methods, to today’s free, official slot demo library at KeepPlay.
mount the image, then run that and it should work fine...
nope, did not work
oh, didnt see that questionOriginally Posted by NetSoerferThis sounds like the image was not created properly. Would you all mind answering my question from earlier about how you created your images?
sorry
I saved it using 120% to my HDD. I have done that with all of my other games, yet I have not seen a game give me as much trouble as this one.
I can play it with my disk just fine, but I have a good amount of disks that is a real pain to keep track of.
sorry again for not answering your question
I copied my disk using 120% and then tried using a variety of programs... everything from 120% to Daemon and other programs like Game Jackal. Nothing seems to work.Originally Posted by NetSoerferThis sounds like the image was not created properly. Would you all mind answering my question from earlier about how you created your images?
