Hi
I installed x3 reunion and then run the game but when open the small window where i can select a graphic card and resolution there is just three blank field. So how can i select a card or resolution?
I also select default resolution etc.. but nothing and when i press start button i get just an error:
Error opening video.
Check your display settings!
Further information can be found in the manual or readme.txt!
Is there any way i can select the resolution? I mean is there any *.cfg file where i can do this?
Please help!
Please help!
