ROSETTA Stone has two disk. One is applications,another is language CD.
I made two ISO files use WinISO base on the two CDs. Then mount the first applications cd to install. Unmount it and mount language cd to run.
But,the software said Cannot locate the CD-ROM, please insert the correct CD-ROM, select OK and restart application.
ROSETTA Stone version is 2.1.3.0A.
Daemon Tools Version is 4.03HE.
Thanks for solution.
