I used Acl120 to make and image, then i burned it to a disk, can someone explain what I do next.
Battlefront2 Backup Not Working.
This topic is closed.
Does the image work if you mount it in Daemon Tools (which is what Daemon Tools is made for by the way)?
edit: I'm slightly confused here after reading what you posted here:
May I suggest to continue this discussion there?Does he even need to burn it? I keep the I keep the image in my docs, and use curerom 1.2 with DT4."I was inappropriately blunt, wasn't I? Sorry, I do that a lot."
