well i purchased this game from a friend recently and im trying to get a working backup running as the discs are already a little scratched. i used ultraiso to create a iso of disc 2 but it will not read. in the database i see that it is safedisc protected so which option do i need. neither the safedisc in DT or SD4Hide will work. i still get the "please insert disc 2" msg. do i have to buy/dl a trial of alcohol to create a working image or is there somthing else im doing wrong?
MechWarrior4 Headachs
Make an image with Alchol using the safedisk 2/3 profile. Then just mount the created image with DT 4. YOu won't need any antiblacklisting tools, this is only required for Safedisc 4.6 and Securom 5-7.
No, Nero does not copy everything that is needed for the copy protection to work.
Use A-Ray scanner (google) to scan the disc for copy protections, then use the right profile for the game in Alcohol. It does work, I've played MW4 (everything except the MechPacks) from images without any troubles."I was inappropriately blunt, wasn't I? Sorry, I do that a lot."
ok i figured it out!!! the game has a static drive letter that it is assigned to. say if you install the game on a cd-rom then play with an iso they will be different drive letters (unless u change them) and it wont find the disk. so to anyone who has problems just install from a backup and you are good.
You can also change your drive letters by clicking on start->run and type in diskmgmt.msc
if you don't want to reinstll the game.
