How do I make a succesfull copy or emulation of GTA : vice city? can anyone help please!
GTA : Vice city - copy problems
Dunno if it will work because DVD cant be burn in RAW Modus and this is necessary for the Copy Protection to work. You can try to make a Good Image with Alcohol, SecuROm 4/5 Profile. Turn DPM on High Precision and Low Speed. Then Burn it on Low Speed with RMPS and try if it works. Otherwise there is no chance of it.
Then when you try your Copy check that RMPS emulation is enabled on DT or Alcohol.
Vice City is just a CD.Originally Posted by MystiqueDunno if it will work because DVD cant be burn in RAW Modus and this is necessary for the Copy Protection to work. You can try to make a Good Image with Alcohol, SecuROm 4/5 Profile. Turn DPM on High Precision and Low Speed. Then Burn it on Low Speed with RMPS and try if it works. Otherwise there is no chance of it.
Ohh, my mistake. I was thinking about San Andreas ^^
Then the Method i wrote should work. Try it.
Btw. You didnt must quote my whole post when you write direct after me
