Toca 3 and Sfcure
  • Toca 3 and Sfcure
    Well i have mounted the image but it tells me to unplug my dvd-cd rom cables and disable watever my cd-rom is set up as and i cant get by this it check and it says failed to find the cd plz retry. Is there any other way around this?
    You've to unplug your drives to play this game using an image.
    It can work without unplugging when you have a NForce 3/4 mainboard (then it can work by disabling your drives/Channel/Controller).
