Hey people i have put down a lot of research and this is the only u can beat secuROM 7 for all types of motherboard
Remove daemon tools 4.xx then..
(Remember though this is only for windows x64 edition)
1.Install the game in windows x64 edition
2.The protection drivers usually STARFORCE will get installed.
3.Reboot the PC
4.Make a perfect mdf file of ur CD/DVD with very low dpm
5.Then install daemon tools 4.xx
6.Mount the image or clone with all emulation options enabled
7.Run the game.
The startforce drivers do not start on 64 bit edition (the coolest part)
and then go play
32-bit users however will either hv to inplug the drive...and if u hv a nforce board then u will hv no probs at all use any one these tools
cureROM
sr7.STOP
virtual cd hide
etc cool isnt it
Hey pls apperiaciate the efforts i put in reseaching and then finally coming with a x64 edition solution...................................
3.Reboot the PC
7.Run the game.
and then go play
cureROM
sr7.STOP
virtual cd hide
etc cool isnt it
