thats great man,I was just about to make a prince of persia thread...anyway,could you please tell me what the scenario would be for me because I have an intel chipset motherboard.
no image soft, but lotsa images!?
thanks man thats great,i was just going to make a prince of persia thread...anyway,could you please tell me what the scenario for me would be because I have an intel chipset motherboard.
And some background info: i installed the game fine,got the serial number fine,then it started checking the disk and gave me an error telling me to put the CD in the drive and click retry.I dont have any image creating software,but I do have some three images that mount just just fine.I use daemon tools v4 and have all options turned on.
I would say No.4 is the solution for your system.
For unplugging the drives you need to open up your pc case, before that shutdown your pc.
Then physically unplug the plugs of your cd/dvd-drives (not the hdds).
Start your pc, mount the image using DT and play.
