Hey everyone,
Its not actually a problem with Daemon tools, but actually looking for some help with this program.
I downloaded the Halo PC ISO Image through torrenting, and I burned it using "PowerISO". At first it ran fine, but had some bugs. So I installed the latest patch: v1.07. Now when I boot it up it says: "Cannot locate Halo CD, Please insert the correct Halo CD, and click OK to restart the application."
Desperate for some help, if you need anymore info post a reply.
Thanks for you help
Thanks for you help
