Dont bother creating an image for the game if u installed using full install do the following:
go to dis link click here.
okay wat to do from here on.
1) u could download the mini backup image jus mount that in a virtual drive using daemon tools and ur good to go the game will run perfectly
2)u could also download a fixed exe any of dem will do den jus unzip the file provided and replace the exe in ur game's program file with the one provided (click yes when asked if u wanna replace) now everytime u click the link on ur desktop the game will run [I personally prefer dis method bcuz i dont like to mount images an all of dat jazz
good luck post back and tell me any of ur results k
________________________________________
may the force be wit u young grasshopper
]good luck post back and tell me any of ur results k
