Hey guys a have a crack for NFS most wanted. It requires to mount a 1.74 GB '.mdf' file. In the crack instructions it said to install DAEMON tools 4 and then make virtual drive and then said to mount it. Then it says right click on the mdf file then go to properties then got advance and select an option that says compres contents to save disk space.But i tried and nor could i find any advanced options nor this option to compress the contents. PLZ Help
