Ok, here is the way to run the game with 1.1 patch without your dvd (cheers to ArtMD64 for explaining)
1.Download and install the patch
2.Download the x200x image from www.gamecopyworld.com
3.Extract the contents of the archive into Hitman directory
4.Download and install the latest Daemon tools (4.03)
5.Remove all the cd images already emulated
6.Mount the x200x image with D-tools
7.Select Securom emulation in D-Tools
(7.5). Restart computer(dunno if it is needed, mine worked fine without restarting)
8.Run asr from the x200x archive (dunno the version)
9.Select HitmanBloodMoney.exe
This method works - played twice, no problem running, no bugs between missions
