i was wondering if some1 oculd show me step by step how 2 set up a 9 .iso program...i have alcohol 120% and daemon 4...ty in advance
Help:not sure on what to do
If the program is copy protected, it won't work with .iso files, you'll need to create mds images with Alcohol 120% from your original CDs. Then you mount the first image, start the installation, and when prompted, mount the next image. Mounting a different image is nothing else than inserting a different CD."I was inappropriately blunt, wasn't I? Sorry, I do that a lot."
