Whenever i try to rename it, it says access denied.... It won't let me do a repair install either. Any suggestions?
Can't rename or delete SPTD.SYS in recovery console
non-standard configuration
You have a non-standard configuration then? Maybe corrupted MTF entries or ACLs applied onto that file. I would insert the hard disk into another machine and investigate methods of deleting that file from windows. Can you boot to safe mode (remember the option to hit the ESC key)? Can you boot to normal windows and run the "sptdinst.exe remove" program?the modern world:
