Is there still no way to get around StarForce v4.0 yet? I know Daemon Tools pro will be able too, but at the moment, there still isn't a way, correct?
Yes, if you burn the image using Alcohol 120% it does start up, but once inside, it asks you for a CD-Key, this CD-Key is the one StarForce has regulated or put in. So they even screw you over once you get into the game.
If someone knows a way to get past this crap, please do share your information. Otherwise, I'll just go buy the damn game, looks like the best RTS in a while from the demo.
-Thanks in Advance.
-Thanks in Advance.
