Sims 2 problem.
  • Sims 2 problem.
    evertytime I try to start it i get an empty error-box. Anyone that knows what the problem is or what I can do?
    Have you tried some anti-blacklisting programs?
    CureROM Support Team
      Dp you mean like Safedisc? Yes.
        Have you updated the game to the latest version?
          Yes I have.
            How did you create your image? Program and settings used?
              Its an mdf-image, should i try another one?
                How created (settings used)?
                  I downloaded it.
