I'm new to all this ,so can you tell me where i'm going wrong.
First i downloaded gran prix 4 bin/cue file then mounted it ,sounds bad "put i went easy on her"the game installed ok
put when i go to play it says {please insert the correct cd-rom
cannot locate the cd-rom i tryed burning from virtual cd/dvd rom to my dvd rom but get same answer NEED HELP
