I need help for Titan Quest Ive tried various methods in the registry to get passed the software that detects emulation and "not original disc" or something but none of them work and I cant load the game
Titan Quest
Same issue here
I just got titan quest, and I am having the same problems getting it to run. I have tried mounting with DT 4.0.3 with SecurRom on and also with SecurRom Hider and SR loader.. SR loader works better than the SR hider, When i use hider it says that a required security measure is not being met, but when i use SR loader it passes security, but tells me to insert the real disc instead of a backup, what step are we missing here to get this to work?
I tried curerom Netsoerfer.. I get the same error as I do when I run via SR Launcher "Please enter original game disc, not a backup"
Any idea how to get around that, it says that if i burn a disc in alch120 with RMPS that it will work, but my RMPS is greyed out for some reason in alch so i cant try that.. Anyway to emulate that effect with programs or registry changes or anything? i have that emulation on in D-tools but not helping.
I'm in the same boat as Bryan. We are all trying to burn the same image, so it was obviously created correctly. Its working for others, just not for me. RMPS is disabled in Alcohol and I have tried every trick suggested here and elsewhere to get it to run off an image
I may be out of line here but:
Without a proper *.MDS file programs such as Alcohol120 can't read the needed DPM from the file to burn with RMPS.Originally Posted by MorphineI'm in the same boat as Bryan. We are all trying to burn the same image, so it was obviously created correctly. It’s working for others, just not for me. RMPS is disabled in Alcohol and I have tried every trick suggested here and elsewhere to get it to run off an image
I may be out of line here but: If you guys are referring to the EmuDVD release of Titan Quest, have another look in the proper *.RAR file and not the *.Rxx
I made this mistake first, I opened a random .Rxx file which only showed an .MDF file, but when I tried to burn: RMPS was greyed out. When I checked the .rar file it contained the .mds file and that fixed my problem
Hmm, do you mean with IT the Titan.Quest.EMUDVD-Unleashed Info ?Originally Posted by Bryan9129Any idea how to get around that, it says that if i burn a disc in alch120 with RMPS that it will work, but my RMPS is greyed out for some reason in alch so i cant try that.. Anyway to emulate that effect with programs or registry changes or anything? i have that emulation on in D-tools but not helping.
Go and buy the Original game and dont use shit like this.1. Unpack the release with WinRAR or equivalent
2. Burn in a120, burn with rmps checked, install DT4 with
vdrives disabled, and enable rmps emulation in DT4.
alternative option is mounting the image with Daemon-Tools with securom loader.
3. Install, use any of these serials :
4. Play
Enjoy Titan Quest, brought to you first by Unleashed.....who else.
Sorry, but this must be said.
