Hey there I was quickly looking around the forums for a guide but couldn't find one (perhaps I didn't look hard enough?)
I was just curious as to whether anyone has (or can write) a step by step guide of how to install Vista using Daemon Tools (I have the latest version)
I tried before and all seemed to work ok, but after installation it would only boot up to a blue screen of death, though safe mode worked fine.. but nothing I did would fix normal start up. Thanks for any help!
P.S. I have just reformatted the C: drive and am looking to reinstall vista.
It sounds like you either have an image problem or maybe a HDD, before you try and re-install Vista again I suggest that you scan your HDD, and if no errors come up try re-downloading the image. You would be surprised by how many people had problems with there downloaded images.
