Hiya all,
I downloaded Commandos SF, mounted the image, installed, used CureRom 2.0.3, did all the right steps but it aint working.
It bypasses the protection but it says: Original disc cannot be found or authenticated
Any1 knows what to do?
These are the steps I followed in CureRom:
1.Create new profile
2.At application the Commandos .exe file
3.Use Deamon Tools
4.The Commandos .mds file
5. Finish
Then the shortcut appears on the desktop, it tries to start but it wont work.
It's very strange cause I did excactly the same with Hitman and that one worked just fine
3.Use Deamon Tools
5. Finish
