If you want to play flatout2 with DT do these steps:
1. Download this file: http://help.starforce.ru/syssum/readcd.zip
2. Unpack the readcd.zip into some temporal folder.
3. Insert the original game disc.
4. Start readcd.exe.
5. Select the number of your drive and press any key in order to close the tool.
6. Send me generated .bin files to ogix7@yahoo.com and then I will e-mail you what to do next.
That worked for me and I'm certain that it will work for you too!
Can you tell some more?
