Hello to all,
first I would like to thank you very much for any help you can give me..
When I tried install the 64Bit version there was immediately an error because my system was not compatible with it so I downloaded the 32Bit Version. (Windows XP SP2)
I started the installation and received the message that the STPD drivers must be installed and they asked me whether to install it or not, of course I clicked yes. After the installation of these drivers was completed, it requested a reboot and so I rebooted my computer. When I logged into XP I saw that daemon tools wanted to continue the installation with the actual program, but then I saw an error message coming up saying something about my SCSI/Raid-Hostcontroller, I do not know what it exactly said, but I saw another error message coming from Daemon Tools, which gave me a simple red cross and it said: Invalid device.
This happened in maybe 1 or 2 seconds and then my computer restarted itself. Not one time, but 10 times until I saw this rundll32 in my taskmanager and I was able to shut it before my computer did another restart, and so I removed everything which had to do with daemons tools. On my hard disk there was a folder named Daemon Tools, but I could not uninstall it so I had to remove the folder manually.
The strange thing is, that before I formatted my computer (this was like 2 months ago) I had daemon tools 3.46 on my computer and it worked perfectly.
Well this is the story and I hope that you can help me with my problem..
Exact error messages:
1st error message: Headline (translation from German to English): Error while undocking from the SCSI/Raid-Hostcontroller
The device "SCSI/RAID-Hostcontroller" can currently not be closed. Please repeat the process later.
2nd error message: Headline: DAEMON tools
Unable to add adapter. Device problem 12.
Sincerely yours,
Gili
P.S.: I am sorry for any typos or gramatical errors, and if you need any further information, please ask, thank you.
2nd P.S.: Forum problem solved, thanks to the explanation of AnalCobra.
Sincerely yours,
Gili
