fixed for those that above methods did not work. I for one tried everything on gods green earth for about 6 hours and finally found this link http://www.mininova.org/activate.php...activate=33346 it leads to another exe file for stacked that is for people who want to play the game but have emulators on their comp and it shuts them out...for example
I would click it and most of the time a command box would appear but disappear just as quickly after using all the files i could find to remove the securom i finally figured out that it was shutting down BECAUSE of the programs i was using so heres step by step of what you do for this game.
-install with any method (i used mounting it to dtools and installing)
-mount or insert cd2
-download that exe file and replace existing one
-start asr.exe (also known as secuROM_loader)(found on this site)(also make sure asr.exe is in the same folder as the exe file)
-choose the new .exe file
-have lots of fun playing me in texas holdem
Hope this helps ill try and remember to check back for anyone with questions
