I just downloaded Prey.
I used winRAR and extracted each CD to one folder. Then i used daemon tools and mounted each .cue file. When i mounted the first one a screen popped up and i installed into program files. When it asked for cd-code i copy and pasted from another website.
This is what someone else said to do but i dont understand him.
"You need to copy the cracked pray.exe located on the dvd rom to your installed pray game directory. When done, the game will run without that problem. "
If anyone can help its much appreciated.
