I have recently downloaded a nice dictionary program.
The program is 2CD's total 1.4GB I used WINISO to burn Disk1(works fine)
The second disk I Extracted to a folder, it has data there is no Autorun file there,so I went to the site where i got the Dictionary and it had this posted.
(QUOTE)
The volume of CD2 is reached 770MB! but this is only a anti-pirate trick,simply burn it into CDR, all will be OK!
or u can use alcohol or DaemonTool to make a virtual CD
I've just tested both images (with Daemon Tools 2.88 under WinXP);
and it works like a charm. Just remember to enable SafeDisk Emulation
(END QUOTE)
My question is what does it mean to make a virtual CD, and to remember to enable SafeDisk Emulation I have downloaded DaemonTools 3.33 (The Info in the folder i Extracted the 2nd CD to looks like this??
Total of 2 files
( Oed3_cd_2 CDROM image files)
( Oed3_cd_2.sub )
I really need this Dictionary. [/quote]
(QUOTE)
(END QUOTE)
Total of 2 files
( Oed3_cd_2.sub )
