global storm cant install
  • global storm cant install
    I installed daemon 3.47 and opened all files to my harddisk. Then started install of global storm but, at %1 ,comes a message " system cant find the explained target" There s a OK button and when i clicked it its gone . What can i do ??
    How didyou create your image? Try recreating your image, maybe yours is broken.
      yes i created a image. Is there any other solution?
        Ok, but how did you ceate that image?
        Do you get the some errors by using the original cd? Or does it successful install the game when you use the original CD?
          i created image with nero. I dont have the orginal cd now, its lost.
