I downloaded and installed SpellForce 2. When the game starts loading, I get the following error message "An access violation occured and the program must quit".
=[ ProtectionID v5.1e ]=- (c) CdKiller & [x/xxx]
Build 17-08-2006....
> Ready
Scanning -> C:\Program Files\SpellForce\SpellForce 2 - Shadow Wars\protect.dll
File Type : Dll, Size : 318956 (04DDECh) Bytes
[!] Starforce v3.7.13.00 (Build 28.02.06) detected !
[!] [PROTECTiON LEVEL] -> Starforce Professional
[!] [PROTECTiON iNFO] -> data protection and StarForce virtual file system enabled
[!] [PROTECTiON iNFO] -> cd/dvd check enabled, identification of emulators is on
[!] Possible CD/DVD-Key or Serial Check -> SerialNumber
- Scan Took : 0.922 Seconds
Scanning -> C:\Program Files\SpellForce\SpellForce 2 - Shadow Wars\protect.exe
File Type : Exe, Size : 14167864 (0D82F38h) Bytes
-> File has 13813808 (0D2C830h) bytes of appended data starting at offset 056708h
[!] Starforce Protect.exe v3.6.10.06 - 3.7.19.01
- Scan Took : 3.203 Seconds
Scanning -> C:\Program Files\SpellForce\SpellForce 2 - Shadow Wars\spellforce2.exe
File Type : Exe, Size : 8211968 (07D4E00h) Bytes
[!] Starforce wrapped !
- Scan Took : 2.750 Seconds
They blacklist alot of emulators ive tired alot of starforce anti things but still nothing Sad
http://m0001.gamecopyworld.com/games...%202%20v1.0%20[MULTI5]%20No-CD/Fixed%20Image
Note: This Fixed Image does only work for version 1.0, it will not work anymore after upgrading to a newer version (which installs a new StarForce v3.7.16)!
if anyone has the link to or files for spellforce 1.00 please email me or something with them
> Ready
