I bought the pc dvd game "HITMAN BLOOD MONEY". My friend came over one day and asked me if he could borrow it to play, and I said no because I wanted to use it. He than told me that I could make an image of it and play it while he just borrowed it.
I don't know what he did but he made an image of the game in a folder. There are two files in that folder:
1. mds
2. mdf
He ended up breaking the damn game by accident, and now I'm stuck with this (mds, mdf) image of the game. I checked out info of this game on your site and found that it uses "secrom". Well what I want to do is basically make a working copy of the game onto a dvd-r or a dvd+r disc so I can play it again.
I tried burning the (mds, mdf) with alcohol 120 software onto a dvd+r, and I ended up with the game! I installed it, but when I tried to play the game it just told me that I needed to insert the original disc due to some "secrom" crap.
QUESTIONS:
1.So how in the hell can I burn this game with the (mds, mdf) files I have, onto a dvd-r or dvd+r disc in order to play it?
2. & if it's not possible to successfully burn this game onto a dvd-r or dvd+r and play it... How in the hell can I use the (mds, mdf) files and be able to play it with the daemon tools software?
P.s.
I've never used daemon tools before, but I am an advanced pc user so you can just tell me what to do. If you give me burning instructions let me know step by step!
Thanks
1. mds
2. mdf
QUESTIONS:
P.s.
Thanks
