I downloaded this game with utorrent.
I used Deamon tools to unpack and installed the game.
I had a serial code I used for the install, it came with the info file with the torrent.
I put the crack exe on the desktop and started the game.
The game starts and the opening movie plays.
Then it locks up, and I get an error message that is just a red circle with an X in the middle.
Can anyone tell me where I went wrong? I have other serial codes should I try them? I assumed if it let the code I type go through the code must be good?
Thanks
Thanks
