Operating System: WinXP
Burning Software: NTI Cd and DVD Maker
Anti-virus Software: Norton Antivirus
DAEMON Tools Version: 4.06HE
I downloaded a DMG file and used Dmg2iso to convert it to an ISO file. No Problem. I downloaded Daemon tools and MacDrive and mounted the file. I can't open it in explorer. I get the message.
Disk not Formatted
Windows cannot read from this disk. the disk might be corrupt, or it could be using a format that is not compatible with windows.
when I read the same complaint from another daemon user he said he could open the file with isobuster pro. I did the same but cannot extract the files without paying 50 bones for it. Is there a way through this.
peace
j5
Disk not Formatted
peace
j5
 Disk Not Formatted
									Disk Not Formatted
