Hi all,
i'm having a problem with DT 4.06HE. I've got an ISO of BF2 (from my disc before it cracks all the way across) and because the disc has a crack across the middle, it takes way too long to start the autorun. For this reason (and because i don't have a DVD-RW drive), i though DT would be a good idea. Now, i want to change the device vendor and model but when i try to, i just get a message saying 'invalid parameter'. That's it, nothing else. Then it goes back to device parameters with the settings it was previously set at (defaults). Not sure whether this is a bug (appears to be) or whether i'm doing something wrong, but maybe someone can shed some light on it.
Also, a feature request, is it possible for you to implement more than 4 drives? Or is it limited to 4 because of would be SCSI limits?
Thanks,
Scott.
Thanks,
Scott.
