Hey Guys,
Mostly thanks to you I got Dark Messiah running finally and I am so gratefull I registered here and will make a good explanation of what to do to make the game work since it still took me 2 days to discover what is wrong. Most steps are already explaned but I found that there are quite some factors that have to be exactly right to run the game, so here is what to do >>
1 Very Very important > Uninstall the Dark Messiah demo and delete all of its content from your PC!!
2 Download Pr0t.St0p to hide all your dvd/cd drives and other drives that must be disabled, keep them disabled at all times.
3 Download the latest version of Deamon Tools (v4.0 or higher) and put ON all emulations! After this mount your image.
4 Now you can install the game, I advise to not install Multiplayer mode with a copied version of the game, cause it needs to be in Steam and online to play and then u can be blacklisted I think. So just install Singleplayer Only.
5 After you have installed the game there is one more thing to do, download the Procyon loader and use it on the Dark Messiah game executable.
Remember to delete your demo, it took me two days of tinkering with all options and emulations to discover that the game really won't run when the demo is installed. Also don't forget to keep your disks hidden at all time when u want to play the game, else it just won't start.
Download pr0t.st0p from here >>
http://cdmediaworld.com/hardware/cdr...html#Pr0t.St0p
Download Deamon Tools from here >>
http://www.daemon-tools.cc/dtcc/down...tegory&catid=2
And for the loader I know Procyon works best, but I think it only comes with your downloaded torrent of the game, so here you can download the latest version of Securom Loaders (Procyon loader = Securom) >>
http://www.cdmediaworld.com/hardware...cuROM%20Loader
I hope this explanation will get you guys to run Dark Messiah perfectly. Also I got a tip for increasing your framerate and loading times, set Texture Qualitiy to Medium or Low and u got 500% better loading times, better framerate and less stutters during movies.
Good luck and have fun all!!
