I need step by step (layperson) instructions on how to get Marvels Ultimate Alliance (which was downloaded) for PC to correctly play.   The instruction with it are:
1. Unrar.
2. Burn or mount with Daemon tools.
3. Install the game.
4. Copy the cracked files located in the Crack directory on the . DVD to your installation directory.
5. Play the game.
I downloaded Daemon Tools but have no idea how to use it to "mount" or "Burn."
Do I have to extract each of the rar files (which are many) if so how do I organize them before I burn. I assumed step one just ment to extract the entire directory. When I try to use the crack it says this:
This application has failed to start because libIGSg.dll was not found. Re-installing the application may fix this problem.
Please help....and remember to try and explain this stuff as if your were explaining it to your mothers
thanks!!!
					1. Unrar.
5. Play the game.
thanks!!!
