Not sure if the post I just looked at is the solution for me or not so im going to post this.
I run yasu, mount SCDA.iso, double click the splinter cell icon, click single player the disc spins like its about to start up and I get this.
Then when I click ok it exits the window and nothing happens, or sometimes when I click ok I get the following error.
It worked fine once, I started to do training it started loading then froze. I tryed Alt + Tab, Ctrl + Alt + delete I finally had to hit my restart button. Every since then im getting the errors I described above.
