Hi guys,
Just finished my exams and thought might try out this great game.
But trying various methods for the last six hours still no luck. I will be very grateful if someone and get me through this.
CD tools installed:-
- Daemon Tools 4.08
- Nero 6
Here's what I can tell you.
1. Firstly I'm confused about which version I have (I got it from a friend)
But in the registry I have this,
Does that mean its the French version ?
2. The size crack I found in the crack folder tell me its the reloaded crack. (2.17MB)
3. Protection ID tells me this,
4. My PC config -
5. Now about the Problem:- I installed the game, copied and overwritten the original exe. But no matter whichever crack I apply I get this error :
(I have tried Reloaded/Vitality/Revolver cracks, all of them one by one)
And when I press Debug Visual Basic always gives me this error:
Unhandled Exception in Runaway.exe: 0xC0000005: Access Violation
and then it points to this instruction:
6. I have tried using a full image (made one with Alcohol) and used it with YASU 1.05. Never worked,
-Mounted the image
- Ran YASU 1.05
- Ran Runaway2.exe
it keeps asking:
Its asking for a CD ?! I dont get it.
Did I get the steps right ?
7. I even tried it on another PC, with P-4 2.4GHz, 1 GB RAM, Raedon 9800 Pro.
- Same result with the image procedure, annoying insert CD message.
- With the cracks, the exe appears on the taskbar for a sec and then disappears.
Sorry to write such looong post. I tried to give out as much information as I could 'casue I really wanna play this game. Please help.
- Daemon Tools 4.08
- Nero 6
Code:
[..] -> [PENDULO Studios] -> [RUNAWAY 2 - The dream of the turtle] -> [2.00.FRA]
Code:
-=[ ProtectionID v5.2b ]=- (c) CdKiller & [x/xxx] Build 16-11-2006.... > Ready Scanning -> D:\RUNAWAY2\Runaway2.exe File Type : Exe, Size : 3416064 (0342000h) Bytes [!] [B]Tages v5.5[/B] (or higher) protected ! [!] protection level: Tages BASIC - Scan Took : 0.734 Seconds
Code:
AMD X2 4400+ 2 GB RAM X1900 XT 512 MB 1 Liteon DVD ROM 1 Plextor DVD-RW (I have latest ATI tools installed and running)
Code:
[B]Runaway2.exe has encountered a problem and needs to close. We are sorry for the inconvenience.[/B]
Code:
00415E2D mov edx,dword ptr [eax]
-Mounted the image
- Ran YASU 1.05
- Ran Runaway2.exe
it keeps asking:
Code:
Please Insert CD of "Runaway 2"
