Originally Posted by Underheaven
MY OUTPUT LOG:
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd" /sddl=O:WDG:S-1-1-0D:PARAI(A;CI;KA;;;WD)S:PARAI : 2 The system cannot find the file specified.
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\Cfg : 1 change(s)
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\Security : 1 change(s)
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\Enum : 1 change(s)
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\cfg" /sddl=O:WDG:S-1-1-0D:PARAI(A;CI;KA;;;WD)S:PARAI : 2 The system cannot find the file specified.
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\cfg : 1 change(s)
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\cfg\" /sddl=O:WDG:S-1-1-0D:PARAI(A;CI;KA;;;WD)S:PARAI : 2 The system cannot find the file specified.
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\cfg\\\0" /sddl=O:WDG:S-1-1-0D:PARAI(A;CI;KA;;;WD)S:PARAI : 87 The parameter is incorrect.
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\cfg\\\0 : 87 The parameter is incorrect.
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\cfg\\\1 : 87 The parameter is incorrect.
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\cfg\\\2 : 87 The parameter is incorrect.
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\cfg\\\3 : 87 The parameter is incorrect.
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\cfg\\\4 : 87 The parameter is incorrect.
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\cfg\\\5 : 87 The parameter is incorrect.
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\cfg\\\6 : 87 The parameter is incorrect.
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\cfg\\\7 : 87 The parameter is incorrect.
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\cfg\\\8 : 87 The parameter is incorrect.
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\cfg\\\9 : 87 The parameter is incorrect.
HKEY_LOCAL_MACHINE\system\currentcontrolset\serv ices\sptd" /sddl=O:WDG:S-1-1-0D:PARAI(A;CI;KA;;;WD)S:PARAI : 2 The system cannot find the file specified.
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\cfg\\\0" /sddl=O:WDG:S-1-1-0D:PARAI(A;CI;KA;;;WD)S:PARAI : 2 The system cannot find the file specified.
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\cfg\\\0 : 2 The system cannot find the file specified.
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\cfg\\\1 : 2 The system cannot find the file specified.
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\cfg\\\2 : 2 The system cannot find the file specified.
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\cfg\\\3 : 2 The system cannot find the file specified.
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\cfg\\\4 : 2 The system cannot find the file specified.
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\cfg\\\5 : 2 The system cannot find the file specified.
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\cfg\\\6 : 2 The system cannot find the file specified.
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\cfg\\\7 : 2 The system cannot find the file specified.
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\cfg\\\8 : 2 The system cannot find the file specified.
HKEY_LOCAL_MACHINE\system\currentcontrolset\servic es\sptd\cfg\\\9 : 2 The system cannot find the file specified.
...STILL GETTING THE CONFIG KEY PROBLEM?
