I downloaded sims 2 from utorrent. it said to come here and use the daemon tools to install the base game, and then install some other file. this is what came in a notepad document with the files:
The correct order is as follows:
The Sims 2
S65D-HGW8-63Q8-MWQ7-KMCZ
University
QL22-Q976-4X8J-QMHX-22PB
Nightlife
ZLJJ-AULF-LQFN-FJQ6-A6CM
Holiday (Christmas) Party Pack
No CD Key Needed
Open for Business
BPY8-4ZD4-LHYW-S57F-UZEK
Family Fun Stuff
F4EN-XDGJ-8HWJ-F8HV-MRLD
Glamour Life Stuff
RYZ9-29RJ-A8J9-E1R0-1911
Pets
AHNW-MG5V-XBOX-LRLD-RULE
Install instructions:
Mount image files using Daemon Tools (http://www.daemon-tools.cc/dtcc/down...egory&catid=5), install base Sims 2 game. Run updater - thesims2_update.exe - then install expansions in order as above. Use exe crack from Pets expansion - located in Crack directory on Pets image - to replace original exe in Pets install dir.
The files are all either MDF or DMG. I dont know what to do with them. Any help? please and thank you.
The Sims 2
University
Nightlife
No CD Key Needed
Open for Business
Family Fun Stuff
Glamour Life Stuff
Pets
