Hello everybody. here is somethong i have just discovered.
I discovered this accidently. While I was waiting for S.T.A.L.K.E.R , have nothing to play, so I want to kill some time. I played GT Legends before, and yes, i had to remove power cables. I do this by no means necessery,and it works. Follow this and you should be able to play like I do
1. copy image from dvd to Hdd.
2.install daemon tool 4.08 HE with SPTD 1.37, and mount the game
3.Install game( with power cables connected to a dvd drive).
4.after instalation go to device menager select dvd/cd drives, click on your drive(s) and go to DISABLE than UNINSTALL
5.Start game, you will be asked to restart
6. after restart do the same thing as in step 4
7.start game and enter this key - FFMGU-HA34Y-V8ABF-VUN3Y-SCTRP
8.play!
I dont know is this because of new Daemon tools or something else.
Hope it works for u too. If not send me e-mail to noodle_007@net.hr and Iґll try to explain if you didnґt understand.
Sorry about grammar.
----Proud to be CROAT!----
8.play!
