folder bug (shows downloaded games)
  • folder bug (shows downloaded games)
    not sure if it is working as intended or bug but here it goes :
    i mount a image.
    test wanna want to test, unmount the image.
    now the problem is i like to delete the folder wich contain that image. pre this version i could delete the folder fine.
    now, it say folder is in use.
    only solution is to mount another image in dt, in another directory.
    after that i could safetly delete the 1' directory.
    sorry for my english.
    Did you choose "Unmount" or did you choose "Eject" to dismount the image?
      Download Unlocker ([url]http://ccollomb.free.fr/unlocker/[url]) and try "unlocking" the folder to see what process has a an open handle on it.
        sorry for beign late.
        unmount is done with unmount option.
        unlocker :
        Upload, organize and share your photos with ImageShack. Fast, reliable image hosting with albums, privacy controls, direct links and resizing.
        so again.
        i mount the file, do my what i wanna do, unmount the file, try to delete the folder, folder is empty, but i canot delete it unles i mount other image, in other directory.
          if it is matter, with "unmount all drivers" option.
            nice screenshot. shows that you don't buy your games.
            we don't support warez here. go away!
              backup copys for my original games ? i supose i need to scan my recipes to report a daemon tools bug or so ?
              or do you think this problem is related and 100% apear only because i use the backup files, not the orginal games, true ?
