So i have a valid warcraft III cd key. i bought it. The discs, however, are old, and damaged. So, naturally, i torrented the warcraft III iso's. I mounted the image using daemon tools and it worked perfect. Installed just fine. Problem is though, is when i run warcraft III it tells me to verify that my warcraft III cd is in my CD-ROM drive and to hit retry after doing so.
It appears that it is not even checking my virtual drive. i have tried disabling my physical drive (using device manager) and it still does not look at my virtual drive.
JUST to make sure my game installed correctly, i used a no cd-crack to see if it would work. It did. I tried alcahol %120 aswell.
Any tips? PLEASE! i must play DOTA again!
*i am running vista home premuim.
