Hi, I'm new (
) and I've a problem. I've The Sims 2 Nightlife and I don't want always insert the cd for play it, I don't want Scratch it and, I haven't now the game because I've gave it at my friend and I don't want wait he re-give me the game! I founded some mini images for D-Tools but I saw thats jobs only on D-Tools 3.47. Yeah, I can install D-T 3.47 but the bigger problem is: I need D-T 4.x version for another game (I haven't nothing copied) that doesn't work whit the 3.x versions....can you help me? I tried too whit Alcohol 1.9.5 build 3105 but the game doesn't work if I install D-Tools and Alcohol 120% 1.9.5 buiild 3105. I tried to turn off D-Tools and I tried ONLY whit Alcohol 120% but, installing D-T (too if D-t isn't in memory) and Alcohol 120% the game doesn't work...Can I try? Whit Alcohol 120%? No! Because the image of second game isn't supported by Alcohol120!
I'm sorry for eventuals ortography errors but I'm italian and I'm learning the English
Thanks for help!
) and I've a problem. I've The Sims 2 Nightlife and I don't want always insert the cd for play it, I don't want Scratch it and, I haven't now the game because I've gave it at my friend and I don't want wait he re-give me the game! I founded some mini images for D-Tools but I saw thats jobs only on D-Tools 3.47. Yeah, I can install D-T 3.47 but the bigger problem is: I need D-T 4.x version for another game (I haven't nothing copied) that doesn't work whit the 3.x versions....can you help me? I tried too whit Alcohol 1.9.5 build 3105 but the game doesn't work if I install D-Tools and Alcohol 120% 1.9.5 buiild 3105. I tried to turn off D-Tools and I tried ONLY whit Alcohol 120% but, installing D-T (too if D-t isn't in memory) and Alcohol 120% the game doesn't work...Can I try? Whit Alcohol 120%? No! Because the image of second game isn't supported by Alcohol120!I'm sorry for eventuals ortography errors but I'm italian and I'm learning the English
Thanks for help!
