when i install it then try to play it says enter the right disk when i do have the right one mounted....this also happened with deus X invisible war...and silent hill 2 when i try to play it..it just wont load...do i have to turn something else on also to play them? cause i found other silent hill 4's and it said the same thing after installing it :/
problem with silent hill 4...and stuff :(
i got the iso from someone
i did read something about silent hill 4 being protected by securom or something what does that mean o.o
(i just thought it had something to do with that? the reason it said insert the right disk...also someone mentioned yasu somewere and i dont know what that is
sorry for the trouble)
