hi everyone...
i've had kind of the same problem...
i've downloaded call of duty 4 modern combat. it was an B6T-file, so d-tools or alcohol120% weren't able to mount it...
then i figured out that i could convert my files into an iso file using ultraISO.
that worked!
now i've installed the game, everything went very well but when i try to play the game, it says that i have to insert the correct cd...
i have no idea what i have to do... i tried using other visual stations but that didn't work... i tried to check my iso file using isobuster, but that didn't give anything... i checked other forums, but i didn't find any solution... is there anyone here that may help me?
thx!!
that worked!
thx!!
