Installshield Wizard Error -6006
  • Installshield Wizard Error -6006
    Operating System: Windows XP Pro
    Burning Software: Roxio Easy CD Creator
    Anti-virus Software: none
    DAEMON Tools Version: 3.41
    Ok...I downloaded Enter The Matrix for PC in CD 1 + CD 2. I use Daemon Tools to mount the CD1.Cue. All is fine so far. Then when the autorun pops up it asks me "Do you wish to instal Enter The Matrix now? Yes No. I click yes. Heres the bad part. The Installshield engine pops up saying "Starting Installshield Wizard..." but so does this other small window ober it with the title bar "Installshield Wizard" and in the box it says with a big red and white X,
    X Setup has experienced and error.
    Please do the following:
    -Close any running programs
    -Empty your temporary folder
    -Check your Internet connection (Internet-based Setups)
    Then try to run the setup again.
    Error code: -6006
    This makes no sense to me . I've done all three things it told me to do and everything. Theres no other way it will let me run that setup.exe on the CD1.cue. Please. Does anyone have any idea as to what else this error message could be trying to tell me or anything suggestions what i might do to get around this. I feel that there is so a simple solutions that i am juss not seeing.
    Error -6006 means "Stupidity alert!" :mrgreen:
      Why do people even waste their time? This user would have seen message box stating that we don't support warez!
        I donґt know - such users are just plain stupid :roll:
          Looked it up in the Microsoft Knowledge Base...
          Error 6006: Invalid User Format
          (The user does not meet the minimum intelligence requirements. Please upgrade the user to a higher intelligence level or get a new user.)
