I downloaded nfs prostreet from a torrent from isohunt.. if you search prostreet it will be in the first few(not from vitality). I mounted it with dt 4.06 which is what it said in the instructions and I installed the game with the serial they provided me with. I then put the crack i got from gamecopyworld.com (there are 3 i took 2 and tried them both out) It then said run yasu... having no idea what yasu was i searched it downloaded it and did the cloaking thing in the begining it used to say cant find controller it may already be cloaked.. then i did some moving and i downgraded from 1.4-1.3 it then worked now ive got the drive mounted ive got the crack fixed in ive got it cloaked so i click on the nfs the box comes up saying Play, Web support, view readme, uninstall, quit and so on so i click play but when i click play it freezes for 2 seconds and the box dissapears without prostreet opening up.. What have i done wrong i meet the system requirments i used daemon 4.06 and yasu 1.3... But during all the install and before cracking and using yasu i kept trying to see if the game would open up and work so is that it?? And it once came emulation software detected conflict or something...PLEASE TELL ME WHAT TO DO!!! thanks
